From the NOS radiators for older models that I saw years ago the paint had a fair amount of gloss to it....but not a high gloss. The 85% gloss sounds about right. The factory paint job was rather crude with poor surface preperation.
Did you check with the local radiator shops in your area for the radiator enamel? That's where I got the paint for my radiator. The paint is really "watery" too so don't spray it on heavy or you will have a black floor along with a black radiator. Gene is right.....the radiators were glossy, but not a high gloss.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I've had good results with Dupli-Color Semil Gloss Black
Joined VCCA June 1, 1961
I think that the base for radiator paint is alkyd. It was always thinned with gasoline in the "good old days" radiator shops. Guess today mineral spirits or varsol is used.
Many utility and inexpensive equipment paints are alkyd based. A gloss or semi-gloss sprayed in one thin coat should do it. Tractor Supply has a line of alkyd paints.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Okay, thanks... I think I've got enough info... You'll be able to see how the 85% glossy looks at Flint. Thanks!!!
--Bill B
Posts: 360 |
I used BBQ grill paint which has held up very well.
karl
