#194396 01/08/11 11:21 AM
I just realized my 33 std sports coupe didn't have a sunvisor when it left the factory. There are no screw holes where it should mount & there are no pockets drilled in either the roof rail or the header for the pin. My other 33 std has all the correct holes. I know RH visor was an option. Was the LH also?
Thanks, Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
I know they were here in Canada Joe so I imagine they were in the US as well. My '34 Standard coach doesn't have a sunvisor either.
Garry
Interesting. I never questioned it before. I always thought the LH visor was a standard feature & RH was an option or accessory....Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
The Eagle (Master) comes as standard with the left visor. The right visor is an accessory and the holes are already marked for installation.
I have been looking for the right visor for my Eagle for several years and have had no luck.
Agrin devil
The LH visor is hard enough to come up with. The RH is next to impossible. Just curios, do you have an Eagle or a Master?
Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
Yes, it is an early car without the permanent window divider, and is a true Eagle.
Original except for a paint job many years ago. Mileage, 54,000. Body style is the coupe, and 6 wheels. Front cover June 2008 G&D.
Agrin devil
The 1933 Standard Engineering states it has a visor and the proving ground test car had a visor. The 1934 Std....same.
Is it just the Canadian cars that did not have a visor?
The 1934 accessory book shows an accessory right hand visor and states it matches the production L.H. visor. No accessory L.H. visor is mentioned.
My '33 Master has the correct pin holes in front and at the side but the visior has been replaced with the wrong item. It does not swing to the side and has no pins. If anyone has the correct hardware and/or visor (Left) I would be very interested in purchasing. I'm at Info@bridgeceekinn.com. Thanks, Gene
I guess they just missed during production. It's the 16th 33628 built in Oakland. Built Feb of 1933. There are no holes drilled for the visor. Weird!!
...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
My Canadian '34 Standard is an early 200 series. It has many "carry over" parts from the '33 Standard model. Like your '33 Joe, mine does not have any pre drilled holes for a left handed visor. I know the Master models had a left handed visor but I have not heard of any Standard models (for these years) that had a factory installed left handed visor.
Gene, There is a Left Hand Visor on E-bay right now if interested, item # 2905223530565. jet
Jon T.
Jonjet #195396 01/17/11 05:09 PM
The correct number is 2905235330565
Neil (Canada)
have a nice day
lucky1 #195403 01/17/11 06:04 PM
Wrong number-I think you have one too many digits.
hoppy
"Four-Doors-Forever"
n2chev #195404 01/17/11 06:07 PM
2905 2353 0565
have a nice day
lucky1 #195406 01/17/11 06:19 PM
OK-that`s a good number and everything looks correct with the visor except it does not have the embossed line around the edge The correct one actually has a widows peak pressed into it.
hoppy
n2chev #195408 01/17/11 07:21 PM
I agree with n2chev. That may be a visor for the 33, but does not match the one I have which has the embossing around the front edge.
I am so frustrated that I am about ready to purchase a plain visor like this one and then go for the right plain visor to match.
I already have a collections of visors which were GUARNTEED to be the correct visor for the EAGLE.
Agrin devil
That's funny, I put too many two's in the number even after I checked it and whoever corrected me put too many threes. Anyway you're right about the embossing and I can't see it in the picture however the picture quality is so poor I don't know how you can see that.
Jon T.
