Posts: 3 |
My 34 1.5 Ton truck is missing the the original seat.Original riser is still in truck. Gas tank is under the seat and fills from inside the cab.Does anyone have a 33,34 or 35 truck who could either describe the seat or take a picture so I have some idea as to what I am looking for. Any help on this matter would be greatly appreciated. :(
Posts: 5 |
Hello Doug1934, I have a 1933 1.5 ton Chevy that I'm working on as time permits. I just got home from work (I work third shift) and need a little sleep. It's a little chilly this morning, around 20 degrees outside, but this afternoon I'll try and get some pictures for you and e-mail them to you probably this evening. As far as I know they are original but were recovered in the 70's so the fabric may not be original. However, it will give you an idea what to look for.
Untill later, Frog
Posts: 5 |
Hello Doug I have pictures of the seats downloaded ready to e-mail to you if you are still interested. I'll need your e-mail address. Mine is lfrog@bright.net Take care, Frog
