What are the STD 1926 Superior V Crankshaft Journal Sizes
Mains: Front Center Rear and Rods
Can's seam to find my handy spec book, wondering if someone could post this info.
darrylkmc
Front main bearing journal is 1.375" diameter,centre main bearing journal is 1.687" diameter,rear main bearing journal is 1.750" diameter.Connecting rod journal diameter is 1.500" diameter.These are all standard diameters.Hope this helps out.
chevy
CJP'S 29
Thanks for the information, and as I suspected, I had my crank turned .020/.020 . I don't have my notes with me but I measured them last night and recall the rod journals were 1.480 and the center main 1.665. And these were just quick measurements to get an idea of where I am at. I was helping to pour the main bearing babbitt for my Model A Phaeton and trying to figure out if I could make a jig to pour the babbitt for my '26 Touring
darrylkmc
Center journal = 1.678, thrust = 1.465
Agrin devil
Thanks for the clarification, I will do some more careful measurements this evening, now that I know the correct dims.
darrylkmc
Dimensions taken from the booklet titled,"What Every Chevrolet Mechanic Should Know",chapter VIII,page 36,dated March '28.
devil
CJP'S 29
"I was helping to pour the main bearing babbitt for my Model A Phaeton and trying to figure out if I could make a jig to pour the babbitt for my '26 Touring"
Let us know if you are successful. I for one would like to try my hand at that too sometime.
Just to clear the information, the figures I gave above in my last post is the WIDTH of the center main.
The reference quoted above does not give this information, however it gives the max front to rear as .006.
Agrin devil
I will post my results, I may not get to setting up a jig until about mid February. Now that I see how the KR Wilson (KRW) tool works I am going to somewhat use it as a guide. It's the 3 different main bearing sizes that will take extra machine work.
No problem, just time and money.
darrylkmc
