Does anyone know of a source for a lamp socket for a 41 license plate?
Thanks, Mike
You may be able to find something that will work at NAPA. You will need to find a socket that has the correct pin configuration to match the bulb and the correct connector in its base. YnZ Wiring is another possibility.
Sid
Blue Streak catalog lists S 38N as a license light socket for 1946-52 Chevrolet. Might work if still available. This is from a 1970 catalog.
Neil
have a nice day
You might also try I & I Chevy Parts { www.iandireproduction.com}
Enjoy the ride,
Michael41
Thanks Guys, but still no luck Will try to post on 37-42 forum, and see how I do? Thanks, Mike
Mike I posted a note on this in another form. I just used a reg socket that fit and slid it in with the lens and cover and screwed the cover on. { I did have to take it apart and solder a ground wire to the side of the socket as the old one snapped in and I could not find the proper one. it works fine.
Chuck the heatingman
