I'm getting ready to dump the 85-90 tranny lube out of my 48, and, replace it with fresh 85 -140. My question is - Is there another fill plug to add lube into the universal joint area that I should put gear lube in as well, or, will just filling the tranny suffice.
Regards:
Oldengineer
The gear oil will not drain out of the U joint area so just add 1 1/2 pints to the transmission. The 140 will gradually work into the area and the #90 will return to the transmission and "mix".
"...just add 1 1/2 pints to the transmission."
Gene,
How and why?
Charlie
YEP! patriot
p.k.
1956 BEL AIR 2 DOOR HARDTOP
