Posts: 145 |
does anyone have a good way to repair cracks and small pieces of the wheel that are missing would JB weld be good and what seems to last the longest
Posts: 598 |
I repaired the cracks on my 36 steering wheel with J.B. Weld, years ago, and It has held up quite nicely. I then painted the steering wheel with several coats of laquer. Richard
Posts: 27 |
Eastwood sells a kit for about 95 bucks with the different grades of sandpaper, etc .... personally my plan when I do my 59 Impala wheel is the JB Weld route.
'59 Sedan Delivery, 70 Chevelle, '93 Corvette Anniversary Roadster .... and other stuff!
Posts: 1,194 |
Posts: 598 |
Now that I see It In print, I did use PC-7 not JB weld. Richard
Posts: 145 |
thanks for all the help i'll try both and see witch one will hold out better
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have repaired steer wheel cracks with 2 part epoxy (Araldite) and to my knowledge no further problems. Tony
Posts: 145 |
Tony where did you get the kit from
Araldite is only a brand name of a epoxy glue available in most hardware stores down here. You mix equal quantity together then apply to the required area and some types sets within 5 minutes others are 24 hours. Where the wheel is cracked through I use insulating tape as a former while the epoxy is setting. It can be difficult to smooth out though. Tony
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
You can purchase a steering wheel repair kit with instructions at the eastwood co. the kit is # 52196Z and cost $49.99. www.eastwood.com
p.k.
