If if you look at the throttle plate with it closed and slowly open it can you see a wear spot where it might be binding. If so you my have to adjust the throttle stop screw. If I remember right the head is recessed and covered, but you can see the threaded part that the throttle stops on. If the head is covered you will have to drill out the plug, and it should take an allen wrench to adjust it. Do not go very far because that is not for idle speed, the idle air control motor does that. You do not need to put the plug back in if it had one.
