#190672 12/06/10 06:03 PM
ArtM Offline OP
What should the front to back (horizontal) crankshaft
clearance be for a 194?
ArtM
The factory center main end play should be 0.004" to 0.006". It is okay up to about 0.010" before something should be done.
ArtM Offline OP
Chipper,
Thanks for the reply. I have the pan off for some other work (rod bearings) and decided to check the end play. It's a loose .010 and a tight .011 so since the engine isn't coming out, that will due for now.
Thangs again.
ArtM
I have a '28 engine that you can watch the front crankshaft pulley move forward and aft when accelerating and decelerating. Makes noise but still running.
