#190442 12/04/10 01:14 AM
Popcorn Offline OP
What is the material,thickness and shape(circle or washer) of the oil filler tube on the 1929 and 1930 chev? I have never seen the remnants of one but see they are listed in the master parts book.
Docs Popcorn Co
The gasket is made of cork and it is a round disc type of gasket.
Popcorn Offline OP
Thankyou Dog!
Docs Popcorn Co
Bow Wow!
NAPA sells cork by a sheet for under $15.00, just the right thickness for your oil filler cap. You can also use the cork for making other gaskets. I made my headlight reflector gaskets by cutting thin strips of the cork. Works great!
My Chevy is over 70 years old and still running great. I hope I keep running cuz I just turned 81 !!
Popcorn Offline OP
What is the correct thickness in inches?
Docs Popcorn Co
Popcorn Offline OP
Does anyone know the correct thickness in inches?
Docs Popcorn Co
1/8"
"It's wise to choose a SIX"
Popcorn Offline OP
Thank You!
Docs Popcorn Co
