#189096 11/19/10 11:53 PM
Anyone know the correct color for the hood hinges? Thanks Denny
Wilwood Engineering1955-1957
Denny
Here is somthing I copied from Camaro Research Group. The hood hinges, latch & striker should be this gray or black phosphate except the spring on the striker which is black...Joe
Re: Correct Hood Hinge Finish
« Reply #3 on: August 28, 2006, 10:19:18 AM »
Dave, I think that's a different Palmetto than the one that sells the zinc phosphate (hood hinges and latch) and manganese (bolts) plating solutions.
Contact info is:
PALMETTO Enterprises
2311 A Old Parker Road
Greenville,SC 29609
864 246 3836
The Palmetto plating solutions consist of a gallon-size jug of nasty chemical that you mix 32:1 with water, heat to 200 degrees farenheit in an aluminum or ceramic pot, then dip your freshly stripped and cleaned parts in for a few minutes. Results are well worth the effort.
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Thank You Much
