Posts: 1 |
can some one help me and tell what the tell tell signd are for a correct close ratio 3 speed manual tansmision are and maybe a picture, and i am new to this site how do i post a picture of my car
i was wrong carols not a dirty bird shes bitchin
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
i have a 250 hp 57 210 with its original close ration 3 speed and the only way i know to differentiate it from the base 3 speed is to disassemble it and count the teeth on the gears. i believe the 57 parts book will list the # of teeth. mike
Posts: 167 |
You could remove the side cover and mark a tooth with a marker, then count them as you rotate the gears.
The gear to count is the main drive gear (input shaft). It has more teeth than a std gear. It is also a larger diameter that makes it as large or larger than the bearing. Been a long time since I had one apart, but I think you have to remove it from the rear of the case. A regular ratio gear can be removed from the front of the case.
It and the cluster front gear, are the two gears that are the close ratio.
Any man that thinks he is too old to learn something new probably always was
If I remember correctly the front opening of the case is larger for the close ratio.
Posts: 167 |
One way to check that is the bearing number for the input shaft.
