Good Evening all,
I just picked up this 1952 Styleline and am trying to find a good discussion board for help. My first attempt (another discussion board) was good for a week or so and then responses just stopped on the following post. Maybe I wasn't patient enough.
I'm just looking for a project that my 10 year old son and I can work on and end up with a dependable driver when he turns 16. I feel better about the mechanical work, the body and paint will be a new experience, but I have a couple of friends that have offered to help.
What I have (as I understand it): 1952 Styleline that was fitted with a 49'-51' front cross memeber to accept a 56' 235 motor. The 235 appears to be bolted to the original three speed tranny and the torque tube is still used. The water pump was shortened to accomodate the longer motor.
I understand I need to stabilize the driveline to minimize movement due to torque and there are two common options:
#1 - Use the bell housing mounts to tie the housing to the frame
OR
#2 - Change the front motor plate to one off an earlier 216 which will mount on the cross member the same, but also include side motor mounts to the cross member to reisist torque.
Any pictures and/or comments of the needed mounts and benefits thereof are appreciated.Was the entire front end likely swapped? or can the 49'-51' crossmember be added to a 52' front end? I've read quite a few positive comments on these old front ends working and driving fine.
I cracked the oil plug tonight and while there may have been a trace of milky oil (water), there wasn't much.
I would like to change the oil in the motor, set up a temp fuel supply, install new plugs and try to start the motor. Is it manditory to throw the radiator and fan back in or can the motor withstand short runs (2-3 minutes) without cooling. The car currently has Champion J-8 plugs, what do most use today? I assume copper core plug wires from TSC or similar are sufficient?
I believe the starter will be fine with 12 volts, but I will likely need an inline resistor for the coil to protect the points.
![[Linked Image from i116.photobucket.com]](http://i116.photobucket.com/albums/o39/treestine/IM000228.jpg)
TIA
Chris
