XBTC Offline OP
Color me stupid on this one, but I've tried every which way I can, and I can't figure out how the headlight assembly goes together.
When I got the car, someone had put a poor sealed beam conversion kit on it, so I'm not sure of the order of assembly.
Could someone please tell me how to put this thing together!
A couple of my problems are:
1) What is the purpose of the inner ring? Does it hold the lens to the reflector?
2) Does the small lip on the inner ring go to the front or the back?
3) What holds the outer chrome ring on?
4) Does the gasket go between the lens and the reflector and if so, why is it so big?
Help me! Help me! stressed
Thanks!
The inner ring and the large gasket don't seem like part of the original assembly, maybe they are part of the sealed beam conversion. The lens is held in place in the outer chrome ring by 3 spring clips. The gasket fits around the outer rim of the reflector. There are two tabs on the bottom of the outer chrome ring, one is threaded for a screw that tightens it on the body of the headlamp.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Actually, the above description is not entirely correct for 1929-1930. There is a large inner ring and a large cardboard gasket. The glass lens goes on the bezel first, and then the large cardboard gasket. Next, the large inner ring is installed into the bezel with the two tabs going down through the slot in the bottom of the bezel. Then, the whole assembly is installed onto the headlight bucket outer rim and a small "through bolt" is inserted into the two tabs sticking out the bottom of the bezel and then it is tightened, thus clamping the bezel and lens assembly tightly around the headlight bucket.
laugh laugh laugh
XBTC Offline OP
Thanks guys, I appreciate it ... I think I've got it now!
What was confusing me was that I thought the inner ring held the glass lens to the reflector. Oviously, wrong again!
It seems so clear now ... duh!
Thanks again!! laugh
Cool! wink laugh dance
Thanks for that correction there JYD, guess you can tell my brain is programmed mainly for 1931.
It's like my browser stopped working after I tried to download a new one from Yahoo.
Man, I know how that is because I have been there and done that......more than once!
drink
