#187582 10/31/10 08:24 PM
I need some help in opening the cowl lights on my '33 Master. I removed the screw on the back end and tried moving the bezel on the front with my bare hands. Wouldn't budge. I don't want to force anything. What is the trick?
Just like you have been doing. Competely remove the screw in the back center of the cowl light and then gently pry off the front bezel that retains the glass lens. It should pop off.
