#18681 08/30/06 07:59 PM
I have gone back over old threads and haven't found anything on the correct air cleaner decal. I thought I would put out a new thread in case I overlooked it. Thanks Clif
#18682 09/02/06 07:23 AM
The folks at I&I Reproductions sell one...not sure how correct it is, but I'm sure those here will know.
All the best, Don
#18683 09/02/06 10:22 AM
Don't waste your money on the decal from I&I Reproduction. The decal is junk! Not only is it incorrect, but when the decal is applied to the black air cleaner the decal technically disappears because the printing on the decal is clear instead of white, and the decal itself is a dark blue.
mad mad mad
#18684 09/02/06 07:55 PM
You can keep the white background by not removing the decal from the backing. Just trim the edges of the white background to match the edges of the decal and then glue it to the air cleaner.
JYD, what else is incorrect about the I & I decal?
If you have old Chevrolets, other old Chevrolets will find out where you live.
#18685 09/02/06 08:10 PM
That will work, but the decal is just that.......a decal and it is not meant to be glued in place on the air cleaner with it's backing so that you can read the print. I&I should have made the decal correctly so that the white print was on the decal instead.
Also, the decal says "crankcase breather".
By the way, did you get my private message that I sent to you yesterday before Chevy Chatter went down?
#18686 09/02/06 10:07 PM
I & I should have made some other things more correctly as well.
No, I can't see any PMs or get into my profile.
#18687 09/02/06 10:50 PM
Ya, I can't either! Okay, send me a repeat (42bill really loves that word) message via email that you sent yesterday as a private message, and I will reply back via email instead.
laugh laugh laugh
