#186125 10/14/10 01:22 PM
Are the 1928 car and 1 ton truck fenders different?
Woodbutcher
1928 1 ton truck use 1927 car type Fenders.
Are they the same size or a larger version?
Woodbutcher
I'm pretty sure the commercial full crown guards and 27 chev guards are shorter than the 28 - another effect of the 4inch longer 28 chassis - but someone may know if you can modify (add a piece in) to make 27 guards fit a 28.
The front mudguards used on the '28 1 ton trucks are very similar to at as the 1926 style mudguards,except that the skirt that goes from the inside edge of the guard down to the chassis rail is longer than the '26 passenger car.This makes the 1 ton truck guards higher to accomadate the 20" tyres used.
chevy
CJP'S 29
