Posts: 91 |
Was going to install top today on 32 Coach that I bought from Hampton. Called them but Saturday so no answer. My questions:
Received #4 and #6 tacks. I suspect one type is used for denim and vinyl, the other for hide'em. Which type for denim and vinyl?
Can I tack denim along all bows? Instructions simply instruct you to "tack or staple in place. Can I glue it to the bows? I would prefer securing the denim to all available wood, as it seems there will be a tendency to balloon.
If someone could answer these questions and provide any helpful tips on the installation I would greatly appreciate it.
Thank you.
Posts: 129 |
"tendency to balloon". your coach must go a lot faster than mine. i am looking at a new top and would appreciate any comments you have after you finish.
they don't make em like they usedta
If it baloons you are using the wrong material.The first top I installed on my '34 back in the early '70's was vinly roof material as used on modern cars at that time.It would baloon at fairly low speeds.The second time I used the proper roof material with a good cloth backing.I believe that I got it from Hampton Coach, it was/is fine.
Posts: 115 |
Just ordered my top from Hampton Coach...will install this weekend and give ya' a status report.
All the best, Don
