#184912 09/29/10 03:23 PM
Hello,
As you can tell from my last few topics, I, or more specifically, my restorer is at the stage of reassembly of sheet metal onto the rolling chassis.
My question relates to cab placement on the frame. The rear of cab rests on wood blocks. Does the cab's outer rear bottom rest on the frame or is there a gap and if so, how much of a gap is correct? Should the outside bottom half of the cab be vertical plumb or is there a slight angle forward?
Thanks in advance for your help.
Regards,
Ken
What year is your truck??
Sorry about that!
1946 1/2 ton
Thanks,
Ken
