Posts: 410 |
Can a 1933 cylinder head with casting number 836961 be used on a 1932 block? Thanks in advance for the info. Cleon
Posts: 13 |
the answer is yes...it worked for me. Do a search on 1929 - 32 Head, not sure about the lenght of the push rods. I had to put the lock nut on the bottom of the rocker arm.
Or you can use the 1933 Master push rods which are 43/64" longer.
Posts: 410 |
Thanks guys. I belive I have the '33 push rods also. Cleon
