My rolling chassie is nearing completion on my 1946 1/2 ton. However, my restorer cannot fix slight fluid leakage coming from the bottom three bolts on the differential cover. He says he has tried new gasket, silicone etc. without success.
Does anyone have suggestions that we can try to fix this annoying issue?
Best regards,
Ken
Clean off all oils and put Permatex on the threads of the bolts.
