Posts: 731 |
Been driving Chevrolets for better than 45 years with a each of the other GM brands thrown in now and then. Those along with untold customer cars I've worked on I've never seen anything other than AC plugs installed from the factory. Until yesterday. At 96,0000 miles my 01 GMC Sierra started showing signs it was time for new plugs. Packard wires were still present but I was totally surprised to find the 5.3L came equipped with Denso Iridium plugs!!!!
Needless to say ACs went back in.
Chevrolet
Valve In Head, Ahead In Value
Posts: 11,162 |
So, are you the original owner of the GMC? using those Denso plugs Seems kinda like towing your show quality 32 Chevrolet family jewel with a F150 or a Tundra!  maybe I need to check the 5.3 in the 05 Tahoe, if I can even find them! It's plugs are original from Chevrolet in Arlington, TX and still going strong at 100,200 miles. However the mpgs have dropped down a mpg or so. I have been blameing the lower mpg because of leaving the car run with the A/C on for the comfort of the puppy dog when she is in the car at the stores.
Posts: 731 |
yep, drove it home with 7 miles on the odometer.
the last 4 fill ups mileage dropped about 2 mpg and started noticing an ever so slight hiccup on light acceleration up a long incline.
number 8 was a bit of a bear but NOTHING like plug accessibility of the F and Y bodies. pulled the end off of only one plug wire.
I'm just curious if this is now common practice or just an instance of using another supplier to meet production demands.
Times they are a changin'.
Chevrolet
Posts: 648 |
I've never seen any other than AC factory installed eaither but i've seen Packard wires on them. I wouldnt get alarmed till you start seeing Hochimin wires and zammamotto plugs.
In my shop, quality is a standard, NOT and option.
I checked with the mechanics at a large Chevrolet dealership last week. They said some engines come with the Denso plugs and some with AC.....and no problem with either. I have seen more than one set of plugs still functioning well afer 200,000 miles.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Boy,
I would hate to try and get a plug out ... after 200,000 miles. I already know how my luck would treat the situation.
Bob
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Happy birthday Bob.
Posts: 1,178 |
Boy,
Bob Amen to that. My son had a VW with who knows how many miles on the engine, we attempted a change but gave up and took it to a VW guy, before I broke them off in th eheads.
If the proper plugs are used they are made from a material than allows them to loosen with no problem. Not like the old plugs 20 years ago when the threads in the aluminum head came along with the plug or the threaded portion broke off.
GM has a general policy to have at least two suppliers for each part. That way if one supplier can't supply the other can. Or if a plant burns down they can still produce vehicles. It also helps control cost both in GM and outside supplier plants.
Posts: 762 |
I just changed the plugs on my 01 Silverado and it had NGK plugs I bought A/C plugs and was surprised when I took out the old ones and saw NGK
Thank you ...I don't feel a day over 68 !
Bob
Posts: 731 |
If the proper plugs are used they are made from a material than allows them to loosen with no problem. Not like the old plugs 20 years ago when the threads in the aluminum head came along with the plug or the threaded portion broke off. been there, done that! a 215 Pontiac. 4 out of 8 pulled the threads. that's why I automatically go to a state of pucker when removing plugs from an aluminum head.
Chevrolet
