#182361 09/02/10 05:28 PM
50 CHEV Offline OP
What is the difference between a 1949-50 (3687631) front hub and a 1951-54 (3694757) front hub it looks like they take the same bearings? Thanks
ROSS
The 1950 has the old Huck brakes and the 1951 the Bendix brakes which makes the brake drums different.
50 CHEV Offline OP
Would either one work as long as you use the right brake drum.
ROSS
Not unless you change the spindle, backing plate and brakes.
50 CHEV Offline OP
ROSS
