Posts: 82 |
How would one check to make sure the mechanical advance is working correctly??
Increase the engine RPM's and check the timing mark with a timing light to see if it advances. The best way is to test the distributor on a Sun distributor machine.
Posts: 82 |
Well..that sounds easy to check!Thanks Dog! Checking it on the machine would obviously require taking out of the car?
Posts: 1,513 |
DON'T forget you have to HAVE a Sun Distributor Machine
