Need help figuring out how to hook up the linkage from the foot feed to the carb, A picture would be very helpful.
Thrasher
Suggestions for replacing running board chrome strips? (where to find them or getting them repaired)
Thrasher
They are available from the Filling Station.
1934 Master moulding had the front peak tip of the moulding swept up in the front and the rear was cut-off square.
The 1935-36 Master had both the front tip and rear tip up-swept.
The 1937-38 Master Deluxe has the tip point centered on both ends. 99 out of 100 Chevrolet people would never know the difference. After the late '30's Chevrolet sold the 1937-38 version for a replacement for the 1934-36 models and this is what the F.S. has. If that minor change dosen't bother you the mouldings can be purchased for the F.S. for $129.50 a pair and a set of the twist type clips for $39.50. The shipping may be a little pricey as they are oversized..
Email me your email address and I will send you a picture
And is it a Standard or a Master with the starterator hooked-up?
thrasher@rap.midco.net
Thanks in advance for all your advice--couldn't do it without it!!
Thrasher
Master.
Thrasher
Oh yea, forgot to add that it's with a starterator.
Thrasher
