#181464 08/23/10 08:29 AM
What is the correct type of lube to use for 6-volt Delco genrators? Same as the engine, like 30-wt.? stressed
As always, TIA Bob wink
Capt. Harley
YES! and don't use too much, just a squirt now and then.....
I prefer to use a lighter weight oil. Actually, any fine oil will work.
I have used 3 in 1 oil from the hardware store for many years with no problems.....
patriot
p.k.
1956 BEL AIR 2 DOOR HARDTOP
p.k. #181491 08/23/10 03:17 PM
The oil actually soaks into a wick for the rear bushing......and the wick rubs on the shaft. I would use a motor oil like 10W-30. Would not use 3in1 as its too light. Not even recommended for eletrical motors.
Thanks guys! I'm in the process of redoing two generators, a 943J & a 946C. New bearings (double sealed ones, so no lube needed), new bushings/wicks, new oiler cups, gaskets and paint. I'm also rebuilding a RJH-08 carb and an extra fuel pump. If and when I finally go on a trip down "that long lonesome highway" with my '29 coach. It will be well stocked with spare parts under the rear seat........ bigl yay
Thanks again, Bob wink
Capt. Harley
Excellent plan.
Agrin devil
Very Interesting comment....
I wonder, should I look under the rear seat of my 1928 sedan?
I found a bunch of stuff under the front seat, but I have never had the rear seat cushion or seat back out...in fact i never thought about how to get it out!, I hardly ever sit back there, I have used the spaceious rear floor to haul all kinds of tool boxes, ice chests, and stuff, that my better half and I "discovered" in various junque shops on tours....
parking auto wavey waveycarbana auto pigs carbana wavey patriot dance carbana
Just take a look in the G&D for the SURPRISE* articles. All kinds of things can get under the back seat.
Agrin devil
When I first got my coach I looked under the rear seat. To see what kind of treasures came with it. I found the original hand crank, spark plug socket and a spare crank hole cover. dance
Bob wink
Capt. Harley
It has been assumed that early open cars came with the top saddles under the back seat. I have suggested to some owners when they contact me as the TA to look under the back seat. Some have found the saddles still under the seat.
Agrin devil
I looked under the back seat of my '30 Phaeton soon after I got it. No top saddles, no tools, no money, no viking hood ornament......... only a mouse skeleton. I often tell my grandchildren that there was a skeleton in the car when I got it and nobody knows the history. Absolutely true.
All the Best, Chip
"It's wise to choose a SIX"
