Posts: 3 |
need help are there any size differences in a master grill shell and a standard one. Having trouble lining up the hood, seams radiator shell must be raised way up to line up hood with body then head lite bars do not line up
Posts: 3,163 |
Yes. The master & standard are different sizes. Give me a PM with your phone number & I can call you about 7pm your time. I have both at home. Joe
Posts: 3 |
ok more help needed seams i have a master grill shell jiacciono was a great help in determining the size to be a master grill, car is a master, hood is also master but still have the issue of the hood not lining up to get the hood to come in we need to space the grill up 1 1/4" then the light bars do not line up
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
If you've had the body off the car for restoration, you may want to double check that all the correct blocks and shims went back in when the body went back onto the frame.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 3 |
the body was off the frame but all wood and spacers were put back as original thanks Chip
