Posts: 82 |
I pulled a thermostat from engine and wandering if I need to put back in or delete it.I know it was an accessory at the time.It would help it to heat up quicker if I stuck with it.What about you other owners..you use a thermstat???pros and cons?
What was your water temperature when the car was running? If the car were mine, I would leave it out.
Posts: 82 |
I think the water temp was say 150 degrees with digital scanner.was not very high.
Posts: 82 |
Looking at bottom of thermostat there is a number..155.Could this mean 155 degrees? The thermostat must not been working anyhow . the opening was in OPEN position when I pulled it out.Should be closed until temp opens it.
