Posts: 93 |
Doing a valve job on my '29 head, we found the manifold sleeves (PN 362704) are very rusty. We're afraid parts of it may break off and get into the engine. The question is, can we cut off the sleeve, leaving the alignment ring, without causing any problems?
Thanks ArtM
Your best bet is to purchase new ones.
Posts: 360 |
New ones are the best bet, they are important to prevent manifold leaks.
karl
Posts: 93 |
I would be more than willing to install new sleeves if someone could tell me who sells them. I don't see them at the Filling Station or on Gary Wallace's site.
Thanks for the help.
ArtM
Posts: 11,162 |
The filling Station: INTAKE MANIFOLD ALIGN SLEEVE 206 216 CID & 1941-49 235 CID FS901 $6.50 per set of 3
INTAKE MANIFOLD ALIGN SLEEVE 235 & 261 CID - Set of 3 Sleeves FS902
Mack, Those will not fit the '29 head. Maybe Skipper knows of a source?
Posts: 93 |
Skip, If the sleeves were only used in '29, what was used in '30? Wasn't that the same head except for valve size?
ArtM
Posts: 11,162 |
I am glad that you have them even if they are in bad shape. Yep, I agree that anyone needing these alignment sleeves should try calling or calling those vendors, even if they don't have a set, they may know someone that does. I knew that the 194 rings or sleeves are not mere rings. I have a part number in my 1929-1954 Chevrolet Master parts manual, also for the 30-31. You can kind of view them online: Group # 3.281 part number 362704 (set of 3) 1929 Group #3.281 Part number 362842 (set of 3) for 1930-1931 This is the link to the parts manual on Keith Hardy's site: Keith hardy parts manualwhich is most helpful....
Posts: 93 |
I found a set of '30 sleeves in good shape. We're going to use those. If there's any major disaster, I'll be back.
ArtM
I don't remember the differences year to year and passenger to truck. They should work on your '29.
Posts: 93 |
Chipper, The only truck sleeve in the parts catalog is for a '29 1 1/2T. There is only one part number for the '30 and '31. It's different than the '29 but as you say it should work. We're going to try it and find out.
Thanks for the response.
ArtM
Posts: 509 |
ArtM, could you take pictures of your reassembly? I would appreciate it very much. I'd like to see the sleeves and how they go in. When I removed and replaced my manifolds, I didn't find any so I didn't know to put any in.
I have checked several of parts books from that period.
Jan & Aug. '29 parts books list Sleeve pn 835953.
Feb & Aug 1930 books list Sleeve (set of 3) Series AC pn 362704 Series LQ pn 362705 Universal (1930) pn 835741
Feb & Aug 1931 Sleeve (set of 3) Series AC pn 362704 Series LQ pn 362705 Universal & Indep (1931). pn 362842
Feb & Aug 1932 Sleeve (set of 3) Series AC pn 362704 Series LQ pn 362705 Universal & Indep (1931) pn 362842 Confederate (1932) pn 836495
Feb 1933 Sleeve (set of 3) Series AC pn 362704 Series LQ pn 362705 Universal & Indep (1931) pn 362842 Confederate & Eagle (1933) pn 836495
So apparently there are at least 4 different configurations to the intake manifold sleeves.
Posts: 93 |
Elderjames; The top image is the sleeve. The bottom image shows the sleeve partly inserted into one of the intake ports in the head. The ring on the end aligns the manifold with the head. Hope that helps. ArtM
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
This is how one manual describes the sleeves. "Sleeves in the inlet ports are an effective aid to distibution, equalizing the wet portion of the mixture and tending to return it to the air stream."
They extend well into the valve pocket area and direct the fuel air mixture to the furthest side of the valve better.
JACK
What the sleeves really do is provide a smooth passage for the fuel/air mixture to flow through. This helps keep laminar flow instead of turbulent flow. The more turbulent the flow of gas the lower the flow rate and higher the pressure drop. It is sorta like porting the head in that section.
Posts: 11,162 |
I just pulled the sleeves out of 2 cylinder heads which i have, A 1931 and a 1932 and i could tell no difference between them.
They measured just under 3 3/8" (3.365") and the diameter measured at somewhere between 1.080" and 1.055"(slight oval) for the thin long tube part. with a metal thickness of .020".
The alignment sleeve on the manifold end is .390" long with a combined thickness of .085" ( including the .020" main tube thickness, so it is .065" or 1/16" thick), and the outside diameter is 1.205" to 1.195" (slight oval aswell) . I have measured the best sample that i have. Hope this helps someone to make some for their cars.
JACK
Well, i must have had 30-31 sleeves in my 1932 Head,They both fitted both heads which i have, a 31 and a 32. What are the measurements for the 32-33 sleeves ??
I did notice that in the intake ports on the 1932 head , it had a slight groove on the lower port surface just in from the machined alignment ring recess.
JACK
I do hope you mean-- get them out of your workshop storeroom??
JACK
