Posts: 26 |
I am looking for replacement rear lower cab corners, door sills and the aprons that go under the cab to the bumper. are these available anyplace? Thanks
Posts: 26 |
I should add that the parts I need are for a 1931 1/2 ton truck
Bow-Tie Reproductions has the most sheet metal I know of. Check with Dale at http://www.bowtiereproductions.com/ Most likely you will get a recording when you call but they will return your call.
Posts: 26 |
chipper
who would be good to rebuild a carb from the 31 truck? Thanks
Both Skip Geear and Chip Sweet have many years experience rebuilding those carburetors. They offer satisfaction guaranteed service. Of course I think Chip Sweet (aka Chipper) does a better job but Skip thinks he does. Go figure!
Posts: 26 |
OK-
Where do I send the carb (s) I have a couple and not sure which is the right one.
Just above your post is the word chipper Click on that, go to profile, and contact him by PM or email.
I sent you PM. You should have a flashing red icon that you can click on to read the message.
Posts: 26 |
I just found out that I still need to locate Patch panels for the bottom of my 31 chev truck cab. Bow tie does not have them. any one else know where they can be located?
