#180429 08/10/10 11:31 PM
MickeyC Offline OP
Hi Guys, can anyone tell me if the headlights on my '27 Coupe have a connector that plugs into the back of the housing?
Same for the brake light also? One more, the armoured headlight wire, is it attached to the body with clips or run along the frame? All help is appreciated. I thought the wiring harness would be the least of my worries!! Pictures would be great!
The head lamps and tail light both have plugs on the wire ends that fit sockets on the lights. Clamps and grommets are used to hold the wires in place. The head light wires are part of a group of wires held by three stove bolts and clips on the passenger side firewall, then two more clips with stove bolts (also hold the engine splash pans to the inside of the frame. Either two or three (can't remember which, can look tomorrow) clamps just behind the radiator for the driver's side head light.
The tail light wires are held by clips nailed to the floor boards on the passenger side of the body and then go through a metal conduit above the gas tank to the light in the center of the spare tire rack.
