The centrifugal advance figure for Delco-Remy distributor model 633-G are as follows:
Advance starts at 700 engine rpm's with 2 degrees advance
At 2,000 engine rpm's,advance is 25 degrees
Maximum centrifugal advance occurs at 2,600rpm's and is
31 degrees.
Advance figures for Delco-Remy model 633-J are as follows:
Advance starts at 700 engine rpm's with 3 degrees advance
At 1,800 engine rpm's,advance is 23 degrees
Maximum centrifugal advance occurs at 2,600 rpm's and is
31 degrees.
Hope this helps.
