langer Offline OP
Anyone out there have an extra rear window frame for the rear window of a convertible? It is retangular in shape and the piece I need is the metal piece in which the screws go through. I have the metal piece that the screws are screwed into and the wood has been replaced but I am missing the other piece. I may have lost it while transporting the car to Az.
Thanks.
Erik Langhofer
Phoenix, Az.
Hi Erik,
I have a couple frames that I accumulated over the years for my '31 cabriolet. I haven't looked at them in awhile, so I may have what you need. Send me a sketch with dimensions and I will check.
Roger
langer Offline OP
Thanks Roger. When I get home I will measure it up.
Erik Langhofer
Phoenix, Az.
langer Offline OP
The measurements are: Outside frame- 6 3/4 inches by 24 3/4 inches. The inside measurements are 5 5/8 by 23 11/16.
The corners are rounded.
Thanks for your help.
Erik Langhofer
Phoenix, Az.
