Hello, I need a key for the glove/rear compartment lock. I have removed the glove compartment lock assembly but I cant see any key code numbers. (1) How can I remove the lock cylinder from the lock assembly. There is a small hole in the face of the lock assembly, can this be used to remove the lock cylinder? Is the key code number stamped on the lock cylinder? (2) Is the key code number stamped on the rear compartment lock assembly/handle? If I remove the rear compartment handle can I see the stamped key code number so I can get a key made? Thanks. Larry
take it to local locksmith and they can either find the number on it or take it apart and cut a key for it.
Ken
Take the door handle out. The code should be on it.
