Does anyone know what year and model vehicle bucket seats would fit my 1953 Chevy truck?
I assume that you are building a modified truck. If that is the case I will tell you what i used in my 52 5 window. I used the seats out of a 2002-2004 Chevrolet Silverado. You have to remove seat framework that is welded to the floor of your truck. The seats bolt in with 4 bolts drilled thru the floor. I used plates on the bottom of the bolts so they wont pull thru the floor in a collision. The late seats also have seat belts built in them. The later center console is too wide to fit between the seats so I used one out of a Dodge Durango. This setup worked out well for me as the seats I got were in very good condition so didn't have to have recovered. Chuick
I sent you a PM. Chuick
I just finished a 53 using same seats as you did so I need a consol so what year Durango did you get out of? I got to have a place to put my coffee cup. Could send a pic so I can start the hunt,
