Posts: 9 |
29 & 30 used a pilot bushing, 31 went to a pilot bearing. the 31 pilot bearing has an i. d. too small for the 29 trans. any suggestions on how to make this work would be greatly appreciated.
Posts: 731 |
reduce the diameter of the input shaft to match the bearing I.D. It cost me $15. I used the excellent innards from a 30 to build a trans for my 31
Chevrolet
Valve In Head, Ahead In Value
Posts: 9 |
Thanks, this sounds like my option.
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
I found an even cheaper solution. Measure the ID of the flywheel bearing seat and the OD of the shaft and go to a bearings supplier with the dimensions. They can supply a double sealed bearing that will do the job -- no machining needed.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 731 |
IF you can find a bearing with the proper dimensions you MIGHT find one for less than $15. I've spent hours going thru bearing specification books looking to alternate engineer a project. sometimes it can't be done. Then again, Auto Zone might have one on the shelf
Chevrolet
Posts: 9 |
I went to Berry-Bearing, a local bearing supplier, with the 29 bushing and the 31 bearing in hand. They could not help me. I think I will just pull the input shaft out of the trans and have it machined down. I appreciate all the suggestions.
I bought the correct bearing in January of this year from Bearings and Drives, Inc., 9 Glenn Bridge Road, Arden, NC 28704 under part number GBC6202-2RS5/8 and paid $7.86 for it. It did a great job of mating up my '31 engine flywheel to my '29 transmission input shaft. Their phone number is 828-651-8724.
All the Best, Chip
Posts: 9 |
This route would be less work and less money. I'll have to give it a try. Thanks for the info.
Posts: 9 |
Thanks again Chip. Trans is installed!!
