trooper Offline OP
RAY: This is what I found #1 side of block 5060359 #2head date I 24 8. #3 block date I 13 8.#4 behind the exhaust manifold 5060359.#5 assembly date ? body no N 18429 (on cowl),9AR 97632 (on seat plate). respectfully trooper
Trooper it looks like the head & block were made in September 1928. The head & block are an original match set.
The ID # 9+ Norwood Ohio Plant
AR (AB) 1928 National
97632 = 96632 car built at Norwood (Mid October 1928)
First car # was 9AB1001
I don't have info on body number N18429
Ihope this helped.
Steve
trooper Offline OP
Thanks Steve: Looks like this was a late production in 28 with matching numbers.Thanks for your help. respectfully trooper
