Posts: 720 |
is the tool box cover on the 1931 5 pass coupe split with lifting holes on each side . no holes .hole on one side . not split but a hole to lift it out . may be the same as coach . need help bad . thanks
Posts: 562 Likes: 1
Posts: 562 Likes: 1 |
If you are referring to the tool tray under the front seat mine does not have a cover. Is it supposed to ?
Dick
Posts: 566 |
The storage tray under the front seat is actually permenantly attached and is part of the floor board and is used to keep your tool pouch, jack, crank handle, and tire pump.
Four doors are great
Hoppy
Posts: 720 |
ON THE 5 PASS COUPE THERE IS A METAL TOOL TRAY NAILED IN UNDER THE FRONT SEATS AND A WOOD COVER THAT GOES OVER THE TOOL BOX WITH OUT THE COVER THE SEAT REST WOULD NOT HAVE ANY THING TO HOLD THE SEATS UP AND THE REAR CARPET WOULD FALL IN THE TOOL BOX. THE COVER GOES FROM SILL TO SILL . IT IS NOT IN CHIPS CAR SO I CANT TELL IF IT IS IN TWO PIECES OR ONE . IT WOULD BE EASIER TO GET THE TOOLS OUT IF IT WAS IN TWO PIECES
All I can find is the 1931 Tool Pan Floor Board p/n 4005934 for Job. No. 31551 (Coach). Seems odd since the 1931 & '32 Coach, Landau Phaeton and Five Passenger Coupe all use the same under front seat Tool pan p/n 4004484.
Posts: 562 Likes: 1
The seat is held up by the rails that it slids on in my 5 pass. Mine was a 60K car and did not have a cover. Interesting !!
Dick
Dick: Is your car a 5-passenger coupe or a 5-window coupe?
:confused: :confused:
A couple of days ago I moved the Landau Phaeton to a new location. I noticed single piece of plywood that sure looks like a tool tray cover. That is despite not being listed in the period parts book. It has one hole in the middle. Since it is under the rear seat springs and I have not checked to see if it fits over the tray, I can not yet be sure if its ID. Will check further when I relocate another car later this week.
Posts: 562 Likes: 1
JYD, mine is a 5 window, I mis read the thread. I hate getting old !!
Dick
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Here's some photos of a Five Passenger tool box with the step-down compartment. Also is a picture of the original plywood floor board. FROM PASSENGNER SIDE ![[Linked Image from barkerville.net]](http://barkerville.net/webphotos/vccachat/toolbox64.jpg) FROM DRIVER'S SIDE FLOORBOARD COVER ![[Linked Image from barkerville.net]](http://barkerville.net/webphotos/vccachat/toolbox68.jpg)
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Posts: 566 |
Very interesting!! Like Pushrod says, it`s not only a cover but the support for the front seats. :cool2:
Hoppy
Posts: 720 |
mr barker this is what i was looking for . the cover is one piece . there are two holes i can see where they go . they look to be a little over one inch in diameter could you verify the hole size . thanks bill
I just went out and measured them. They are 1 1/4" in diameter.
Good luck!!
The one in my 1931 Landau Phaeton only has one finger hole. Apparently the body was built in Cleveland (no plant id on the Fisher Body Plate). Maybe it is a situation where different plants made the parts with slight differences. It sure would not be the only time it happened.
Posts: 160 |
Is the tool box cover on a '32 5 passenger coupe split so you don't have to have both seats folded? Mine is-seems a better idea. Was there a rubber mat or carpet originally in the bottoms of the boxes? How about in the trunk? Thanks for reopening this.
Heart of Route 66 Region (Okla) VCCA Chevys: 1929 LQ 1.5T; 1930 LR 1.5T; 1932 BA 5 pass coupe; 1941 Chevy 1.5T US Army Fire Truck, my vintage '82 Chevy Motor Home
