Munch Offline OP
I have several radiator shells that I have bought for my 1930 Coach, but not sure which one is a geniune 1930. Can you share me some deminsions or something to look for?
1929-30 shell has one hole each side for headlight wires, 1931 shell has addition left side hole for horn wire.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Munch Offline OP
Thanks very much.
The '29-'30 radiator shell also has the inside opening at the top mostly straight across. The '31 (also 32 truck) has a slight arch at the top opening.
The 31 shell has a small hole on each side on the bottom for the chin moulding to attach. These holes face the front of the car. 29/30 does not....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
