#175858 06/16/10 11:06 AM
virg912 Offline OP
How do I unhook the clutch pedal so I can pull eng. and trans.? On a 50 sedan. thanks Virg
virg912 #175914 06/16/10 08:19 PM
Virg,
Unhook the spring, remove kotter key from rod in clutch pedal, remove rod from pedal. Then remove other end of rod from the clutch adjustment on the fork and then remove the adjusting rod from the fork by removing the end bolt. I just put mine all back together yesterday so it's fresh in my mind. Donn
old51sedan #175950 06/17/10 06:26 AM
virg912 Offline OP
Thanks Don, once I get that done and unhook the driveline I think I'm ready to pull it. I think I will have to remove the grill or the hood but those springs on the hood are really stiff...Virg
virg912 #175953 06/17/10 07:26 AM
yes, remove the hood, grill, radiator and radiator support. I just took mine out and it helped to clear the way! I also remove the 2 brackets on the bell housing that the rear mounts bolt to.
1951 Chevrolet Fleetline Deluxe
1972 Chevrolet Chevelle Malibu Convertible
virg912 #175954 06/17/10 07:28 AM
Virg,
If you remove the grill and the radiator support, you won't need to remove the hood. Hook your lift chain to the third head bolt from the rear of the engine on the right side and the fourth head bolt from the rear on the left side. Cinch your lift close to the engine and it will lift out perfectly balanced and you won't get close to the hood. Those lift points are per the shop manual. I just pulled my 216 last weekend on my 50 and it went real smooth. Of course I'm assuming that you're using an engine lift and not an A frame and hoist.
1950 2Dr Styleline Deluxe
1950 3600 Flatbed
1970 Impala Convertible 454
DrScotti #175982 06/17/10 02:07 PM
I'll second the motion to remove the rear mounts attached to the bell housing. They will definitely hold you up. I found that out the hard way.
1950 3600 Flatbed
virg912 Offline OP
I'm removing the trans. with the eng. so it will come out together. The eng. I have going in is a 54 that came with a PG so I will have to change some things, someone mentioned changing pilot bearing....Virg
virg912 #176039 06/18/10 08:04 AM
virg912 Offline OP
does the splash pan come off with the grill? Virg
virg912 #176069 06/18/10 04:15 PM
you do not need to remove the splash pan.
virg912 #176167 06/20/10 07:38 AM
Virg,
I just put a 54 powerglide engine back in my 51, yes you need to install a pilot bearing. Also a good time to install a new clutch if you need one. On the two front mounts, I had to drill holes below the timing chain cover for mine. Once I got it in I had to move the gas pedal linkage on the block about 3-4 inches forward to line up with my carb. I'm still playing with it and no other problems so far. Good luck, Donn
old51sedan #176483 06/24/10 09:14 AM
virg912 Offline OP
Do I take out the 4 bolts where the driveline ataches to the trans.? also now would be a good time to do the master cylinder to I suppose....Virg
virg912 #176493 06/24/10 02:02 PM
Yes this would be the time to do the master cylinder!
virg912 #176615 06/26/10 08:44 AM
Virg,
You need to unscrew the speedo cable from trans along with removing the linkage arms so you don't bend them. You need to take the two bolts out of the bottom of the trans mount, then unscrew the coupling on the driveshaft behind the trans and it will all slide right out. It's best to prop up the drive shaft, if you don't it will fall down to the floor. It would then have to be lifted with a jack & you may lose oil all over the floor. Donn
DrScotti #176731 06/28/10 10:49 AM
virg912 Offline OP
I have the 4 bolts out where the front ujoint is but I can only get the collar to move back about 1/4 of an inch to get to the ujoint Virg
virg912 #176733 06/28/10 11:49 AM
The four small bolts hold the bell cover , which in turn holds the bell joint forward, the bell joint must be slid back down the torque tube housing. There is a round collar screwed onto the rear of the bell next to the torque tube. You will need to clean all the grease dirt and rust off the small part of the torque tube, then loosen the seal nut by screwing it off the end of the bell housing and when it is really loose the bell will rotate and slide back toward the rear of the torque tube uncovering the U joint,(Back to where the torque tube tappers up to full size). You can then flatten the ends of the U joint trunnion bolts lock clips and remove the bolts with a 7/16 box end wrench and part the U joint. You will probably need to buy new bolt locking clips and maybe a new U joint trunnion bearing kit from one of our vendors like The Filling Station or Chevs of the Forties or Obsolete Chevrolet Parts Co., if your U joint is too loose.
Here is a link to Keith Hardy's website Old Car Manuals Online
1949-1953 Chevrolet passanger Car Shop Manual
1949 - 1953 Chevrolet online shop manual
MrMack #176745 06/28/10 02:51 PM
virg912 Offline OP
Thanks I think I just about have it laugh cool
virg912 #176826 06/29/10 11:58 AM
virg912 Offline OP
Ok...got the front ujoint unhooked....while am doing this eng. swap...how about putting in an S10 rearend and have an open driveshaft? I heard one from a 4 WD is the one to use ...but why 4wd and not 2wd? Thanks in advance....Virg
virg912 #176847 06/29/10 04:01 PM
A 4WD S-10 rear end is about 2 inch's wider than the 2WD, I have the 4WD rear end in my 41 and used one in a 40 Buick Century for a friend.
dens41 #177245 07/05/10 12:36 PM
virg912 Offline OP
Got every thing unhooked cept the thing that has to do with the clutch...the adjusting rod I think it is...it's hanging up to the e brake bracket ...I can not get the nuts off (the double nut thing) it is really hard to turn..should it be that way??? Virg
virg912 #177300 07/06/10 11:58 AM
virg912 Offline OP
Never mind..I cut the nut off...hope I never have to pull it again...Virg
