#175507 06/13/10 07:21 AM
Bobv Offline OP
I have a 1950 styline that has new headliner installed but not the visors. I can't seem to feel the visor mount holes thru the headliner and don't want to poke holes looking for them. Anyone have a photo of the mount location without the headline installed? And maybe some dimensions to help locate them? I also don't know what type of screws, machine screw or sheet metal and length used to install them.
1941 Coupe
If you use a small sharp needle or pin you can probe the material without damage. Does not work on vinyl or leather but does on any woven material.
Bobv Offline OP
I will give that a try, thanks.
1941 Coupe
