The horn on my 1966 chevelle SS just stop working. I checked voltage at each horn and they work.
Is there a way of checking to see if the horn relay is working.
Hi Tony,
I assume you tested both horns by unplugging them and jumpering a direct 12v from the battery and they are loud and proud<g>.
A quick horn relay test would be to leave both horns unplugged and push the horn button on the steering wheel while listening for a definite clicking sound coming from the horn relay.
If no click sound is heard,test all your under dash fuses.If all fuses are good I'd take a real close look under the steering wheel horn button assembly for any broken small spring,etc...Good luck,Jim
