#174301 05/26/10 07:01 PM
My 1926 that I just got running runs rich even with the IVM screw turned all the way in. This was rebuilt by a VCCA rebuilder. Is there some thing that may have been missed? As you turn the screw out engine runs rough and the further out you turn it it finally stalls.
Woodbutcher
Contact the member that rebuilt it for you. I'm sure he would like for you to have a good working carburator and will stand behind his work.
Agrin devil
If it's like the 28 Carb, the normal setting is 1 to 1.5 turns back from fully screwed in. In is rich, out is lean.
Cheers
Ray
woodbutcher, Does your 26 use the vacuum fuel pump? If so you may be sucking extra fule through the vacuum tube directly into the intake manafold if the float is not shuting off the vacuum valve compleatly. I cleaned my carburetor fifteen times before I found the problem in the vacuum fuel pump. Hutch
Listen to the "click'n" of those push rods
I'd like to bring every one up to speed here. Maybe some can learn from my mistakes. 27 head after extesive work still had cracks and is now a boat anchor. Took a 28 head off a truck sitting in my yard, and installed that. Still running rich. Took carb apart several times. Finally found float was catching on float bowl. Made that adjustment. Also took top off of vacuum tank. One of the springs to close down vacuum had fallen off and was sittingin bottom of tank. Reassembled,and now all seems well. Will take tomorrow to my daughters senior dinner for parents. Theme is roaring 20,s.
Woodbutcher
