Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
I use a 1940s style 2 brush 30 amp generator on all of my old Chevies ('33,'37,'48). On the '37 and '48 as soon as I start them the generator kicks in and is charging but the one on my '33 has to be reved up a little before it will kick in and charge. Once it is in it charges fine but I can't figure out why it has to be reved a little before it will kick in. The regulator is a rebuilt. The voltage on the battery post is 6+ volts with the engine off and aproximately 8 volts when the generator is charging at fast idle. Any Ideas or suggestions to check? Thanks in advance for any suggestions.
Ed
The cutout in the voltage regulator made need adjusting. I would try a regulator from one of the other cars.
Thanks Gene, I had thought of that but haven't tried it yet. I did try letting some spring pressure off the cut out points but didn't want to go too far as it didn't seem like it had much tension on it. I will try switching the regulators and see what happens.
Ed
