#173682 05/17/10 08:04 PM
As part of changing the front motor mount so I can put a 235 from a 1961 in my 1937 chevy, I have to reassemble the cam shaft, timing gear, etc. Does the paper gasket between the block and the timing plate need gasket sealer? I would not think so.
If it were me, I would use the gasket sealer. It might not be correct,but how could it hurt?
