#173554 05/16/10 05:20 PM
Bama31 Offline OP
I just discovered the front I-beam axle on my 31 Sedan is bent. There are photos at http://31chevyproject.shutterfly.com/869#870.
I am guessing this can be straightened by a local body shop that has the capability? Probably should have it checked for cracks also? Does anyone have any other suggestions?
Thanks much,
Ralph
"Roll Tide"
Yes the straightening of the axel is doable.Using a screw on the hub front end aligning gauge a piece of rail road train track a
piece of chain and a 6T bottle jack will bend without harm..
I have done this on 25-26-27-31 chevys and a 34 ford that I hit
a concrete culvert with the left front wheel.
roy
Or, you can come to my house and pick up a spare I have. I don't live that far from you - Tallahassee
Peter
My Chevy is over 70 years old and still running great. I hope I keep running cuz I just turned 81 !!
Any body shop should be able to handle the job, also most front end shops. The Ford PUs for many years had twin I beam front axles. They were adjusted by bending.
I have done the railroad track, chain and hydraulic jack to straighten dump truck frames to be fish plated and whamper-jawed front axles, which ain't rocket science, just be sure that the train isn't going to use the track around the same time! it makes things a bit complicated! as " old Red Green" would say!
