#173501 05/16/10 12:44 AM
Today I turned on the ignition switch to my 37MD. And the amp meters needle went to discharge, just past center peg. First time its ever did that. When its running, it will charge just fine. After trying this a few times, it did every time. Is this a problem that's going to get worse? Thanks,
_________________________________
Joe' 37
Joe's 37 #173503 05/16/10 01:03 AM
If the points are closed in the distributor (and they usually are) when you turn on the ignition, the amp meter will read three or four amps on the discharge side.
Joe's 37 #173517 05/16/10 09:06 AM
Joe
I would consider that as "normal" and not worry about it.
tonyw #173531 05/16/10 12:19 PM
Thanks for the info on this guys. I was thinking that I had a ignition switch or amp meter or something going on it. Thanks,
______________________________________
Joe's 37
Joe's 37 #173538 05/16/10 01:06 PM
You bet and good luck!
