Posts: 230 |
I am rebuilding my 29 chev original engine, straight 6. I see in the Service manual the recommendations for proper torque is, "tighten evenly". To those who have done this before do you have any recommendations for torque and gaps for the following components: rod bearings, main bearing, end gap on the rings and the head torque? Tighten evenly does not seem to be sufficient. Thanks for your assistance.
Erik Langhofer Phoenix, Az.
Posts: 558 |
langer, Bill Barker has collected a load of info on rebuilding and restoring these old engines and cars. Although his site is primarily aimed at the 1931, much of the info is applicable to other years. Here is the link to the torque settings: http://1931chevrolet.com/torque.htmThe home site link is: http://1931chevrolet.comJust be warned, that the old head bolts may stretch when torquing them back down. New bolts would be recommended. The Filling Station, I think, carries them. Good luck with your project, Dan
Posts: 49 |
When I removed my head all unlocked at 60 foot lbs hope that helps, no info on the rest
