Posts: 51 |
Well, I retimed the engine per the procedures and now the car won't start at all. I checked the spark at the plugs and it appears weak. My points don't look old but the moveable part can easily move up and down. I think I have either a bad coil,points, or rotor. Where do I start?
BobK
Posts: 1,049 |
Bob run a hot wire from positive battery to coil terminal that does not go to distributor, if this jumper works you have a problem with your wire loom ignition switch side. if this does not work try filing points cleaning contacts. See if that works. Ken 45145
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 911 |
For sale 29 sedan for sale newtop,fuelpump,carb.,good paint, runs good. Roger- rtpfaff@cpcinternet.com 85oo thanks
Hey Roger! If your car is a 1929, for a better response you might want to post it in the 1929-32 forum and in the "Cars For Sale" forum, instead of here in the 1912-28 forum. Good luck my friend!
Posts: 911 |
I guess I still aint no good at this, but I do not think I can blame this goof on the computor, just me, sorry, it is a 1926 And it is still a nice car. Thanks Skipp
Posts: 911 |
Posts: 154 |
Bobkra, A weak spark could a sign of a bad or missing condensor or bad condensor ground. The coil alone will give only a weak spark. Try a 6V condensor from the parts store and see if that works. It did for me. Hutch
Listen to the "click'n" of those push rods
