#172334 05/03/10 11:14 AM
dandyd Offline OP
I have been involved with Chevrolets (6&8 cyl.)for over 60 years, but know nothing about 4 cylinders.
I picked up a couple of supposedly Chev. 4 cyl. heads at the Pate swap meet this past weekend. They have the following letters & no's stamped on top 32620, Mason, F & MP Co.,
date code 4-0-7 B
Are these 1927 Chevy. heads?
DD
dandyd #172360 05/03/10 03:03 PM
dandyd Offline OP
Any ideas
dandyd #172364 05/03/10 03:57 PM
If you go here
http://home.earthlink.net/~scrippsbooth/chev490cast.html
it looks to be 1916
partsnjunk #172438 05/04/10 10:19 AM
dandyd Offline OP
Thanks for the information. It looks like I misinterpreted the date code. According to the information it looks like you are correct, the 407 B indicates that the heads are for 1916.
Trying to identify the engine block will be next.
DD
dandyd #172440 05/04/10 10:43 AM
If you go here
www.reginaantiqueauto.ca
then tech library and download the 490 parts book the photos
will make identification easier.
Early engines were thermo syphon cooling and had a plunger oil pump. You can also see the differences of the early and late heads.
